SlySoft AnyDVD 2.1.0.9 est dispo !
SlySoft anydvd 2.1.0.9 est dispo ! Voici les changements apportés :
- New: Added option to start external programs on disc insertion of non-Video material
- New: Added option to start external programs if material has 60 Hz refresh rate (NTSC)
- New: Added option to start external programs if material has 50 Hz refresh rate (PAL)
- New: Added option to start external programs on disc removal
- The above options are useful to adjust the screen refresh rate to the inserted media contents
- New: Added utility "SetDisplayFrequency" to set and reset the refresh rate of your monitor or beamer
- External tools like MultiRes or PowerStrip can be used as well!
- New: Removed "Information" Menu Item, added "About" Tab in settings window
- New: If a DVD drive is added or removed, the drive selection list will display this change immediately
- Bugfix: After settings were changed, changes did not become effective before a media change
- Bugfix: anydvd accidently started a rescan, if non CD/DVD drives/volumes were added or removed (e.g., USB Sticks)
- Bugfix: If a DVD-ROM didn't had a drive letter assigned, the settings dialog could display a "Index out of bounds"
  error message!
- Bugfix: If anydvd was enabled, dvd-ram was read only
- Removed ElbyCheck.exe from distribution
- Added Swedish language, updated many other languages
Bon ben ... pour le moment le site de Slysoft semble completement saturé. Pas moyen de télécharger cette nouvelle version pour l'héberger en local :/ :voila:
