Salut à tous
un ami fan de la série des flight simulator, voudrai faire l'acquisition de ce dernier FS X.
Par contre j'ai peur qu'au niveau de sa machine sa bloque un peu :
AMD athlon 64 X2 4000+
2 go de ddr2 pc 5300
Hdd 250Go
Nvidia 8400GS 256mo
A votre avis est ce que ça sera quand même jouable sur cette config (même au mini des détail, il s'en fou un peu, du moment qu'il puisse jouer)
Merci :biere:
Minimum :
CPU
Minimum: Pentium III/Athlon or better
You Have: 2 processors running - Intel® Core2 Duo CPU E6750 @ 2.66GHz
PASS
CPU Speed
Minimum: 1 GHz
You Have: 3.00 GHz Performance Rated at 5.85 GHz
PASS
System RAM
Minimum: 256 MB for Windows XP, 512 MB for Windows Vista
You Have: 2.0 GB
PASS
Operating System
Minimum: Windows XP
You Have: Microsoft Windows XP Home Edition Service Pack 2 (Build 2600)
PASS
Video Card
Minimum: 32 MB 100% DirectX 9.0c video card with Pixel Shader 2.0
You Have: NVIDIA GeForce 7900 GT/GTO (GeForce 7900 GT/GTO)
PASS
Video Card Features - Minimum attributes of your Video Card
Video RAM: Required - 32 MB , You have - 512.0 MB
Video Card 3D Acceleration: Required - Yes , You have - Yes
Pixel Shader Ver.: Required - 2.0 , You have - 3.0
Video Card Driver Version (DirectX)
Your driver version number is: 6.14.11.6904
FYI: Your video card driver version is provided for your information, but it is not part of this analysis. But proper video card driver versions are important to the proper operation of your product.
DirectX Version
Minimum: 9.0c
You Have: 9.0c
PASS
Sound Card
Minimum: Yes
You Have: SoundMAX Integrated Digital HD Audio
PASS
Sound Card Driver Version
Your driver version number is: 5.10.1.6110
FYI: Your sound card driver version is provided for your information, but it is not part of this analysis. But proper sound card driver versions are important to the proper operation of your product.
Free Disk Space
Minimum: 14 GB
You Have: 33.4 GB
PASS
DVD
Minimum: Yes
You Have: LP1470B FPI152D SCSI CdRom Device
PASS, but the Speed could NOT be analyzed.
Il faut tout ça au minimum et tu les as, et même en recommandé tu les as.
Après si tu veux tester les jeux vis a vis de ta config je te donne ce lien ici.
Pour Flight Simulator X faut voir a Microsoft Flight Simulator X
Après dedans il te détaille la config minimal et recommandé avec l'autre onglet :biere:
c'est marrant , dans le lien que tu as doné Charp , il faut au minimum une carte 32M pour le jeu , j'ai une 128 et ca passe pas au test :dingue:
